how to copy a sketch
conjured2018
conjured2018
hi, can one tell me how to copy or duplicate a sketch? thanks jr
jhackney1972
Video will show how.
John Hackney, Retired
_SycTech_
  1. Right-click on the sketch you want to copy
  2. Click the 'Edit Sketch' option from the dropdown
  3. Select the sketch components you want to copy
  4. Press Ctrl+C --OR-- right click and select 'Copy'
  5. Click' Finish Sketch'
  6. Create another sketch on the plane of your choice
  7. Within the new sketch, press Ctrl+V --OR-- right click and select 'Paste'
---- Click the 'Accept Solution' button if this response helped answer your question ----
_SycTech_
g-andresen
Before the how, you need to answer the question for what purpose a sketch should be copied.
Günther
conjured2018
guenther, hey there, I just watched an old Kung Fu and I heard the old priest whisper in my ear, :what is your purpose grasshoppper? I my case what is  your purpose Hog?
this may be an other topic: heres what I do: I make a piece of furniture and model in 3d. I then split body to 3 inchs and lay out on bed. Layout 1 has the two leg assemblys, identical profiles yet layed out across from eachother.
I have found due to flaws in the design process that I can not just select a 2d contour cleanly I make many alt selections to complete the edge cut or contour. I now sketch the outline of my body and then select the sketch for the 2d contour operation in one click.
so I look at design and say instead of making 2 sketches just copy. JR
conjured2018
thank you fellas for your courtesy. JR
