How to convert stl into a solid body with infill
Monodon
Monodon
How to convert stl into a solid body with infill ?
I have a scan in stl format but after importing to F360 I need to make a body from it to perform substract etc operations.
laughingcreek
it's usually a bad idea to convert a scanned stl to a body in fusion.  there are several workflows you might use, but rarely will direct conversion be the answer.  if you post your model, or at least some pics, we can give you some ideas on a direction.
@Monodon wrote:
...I need to make a body from it to perform substract etc operations.
not necessarily.  instead you can convert bodies made in fusion to meshes and do the subtractions  in the mesh environment.
