- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to convert from using Rhino to Fusion 360. I can't seem to build this part...
Here is how I would build it in Rhino.Simple Cylinder with hole
Draw o-ring fgorve dimensions
Create two spheres that intersect the edges of the oring gove and the center of th hole
Now create a curve from the intersection of the shpere and the cylinder
now sweep (2 rails) the profile
Subtract theat shape and my pring grove is correctly sized and correctly perpindicular to my cyyliner face all the way around.
I have three Fusion problems...https://a360.co/2Lhvter
1)I Can't seem to draw the spheres based on features, only on dimensions.
Its easy to get the center of the spheres right, but I'd like to draw the sphere from the center to a point on my oring grove.
2)I can do the math/trig and get the sphere dimension, alas even after drawing the sphere I can't generate a curve of the cylinder/sphere intersection.
3)I believe (bbut do not know) that once I create the curves I can sweep my o-ring grove.
Help...
