How to connect finger hinges
Message 1 of 10
I have two finger segments where one has a hinge hole gap for a hinge pin to go through and the other has a hinge pin at the top of it. I am going to 3D print both objects.  I want to connect the hinge obviously but i am wondering whats the best way to do it and am rather stumped about it as it is blocked off by the sides.
How would i go about joining them?
Heres an image:
Replies (9)
Message 2 of 10
SaeedHamza
This is a simple Revolute Joint
Go to assembly menu in the model environment
Regards
Saeed Hamza
Message 3 of 10
Could you elaborate in a bit more detail?
Im worried if i just put the pin through the hole and join the two, it will print out stiff and unable to rotate.
Message 4 of 10
lichtzeichenanlage
@Anonymous: I'm a beginner. Perhaps things are to complicated in my solution.I tried to find a solution without manually offset anything. Because of this I've create custom origins and than I've created the joint.
Message 5 of 10
lichtzeichenanlage
@Anonymous: Missed to insert the screencast. sry.
Message 6 of 10
SaeedHamza
@lichtzeichenanlage
I appreciate your effort but the whole joint origin thing isn't necessary
Saeed Hamza
Message 7 of 10
lichtzeichenanlage
I wasn't able to select the center origin if I just have two components with one boddy. I didn't want to reposition the joint manually. What would be the better way?
Message 8 of 10
SaeedHamza
You can use the ctrl key by holding it to get the center
Here is a quick screencast to make it clearer
Regards
Saeed Hamza
Message 9 of 10
lichtzeichenanlage
Thx. That's a great hint. Didn't know this.
Message 10 of 10
davebYYPCU
Print them all at once, the print in place method,
test print some cylinders and pins to find the sweet / compatible dimensions.
