How to connect 2 lines that isn't in the same sketch
nitrogamer367
nitrogamer367
See attatchment below I have 4 of these triangles that i made out of lines How do i connect these lines so that it fits into the curve and create a slope, Im just new to modeling so if i did anything wrong please help correct me
jhackney1972
You will get quicker and more relevant answers if you add your model to your forum question. Please do so.
John Hackney, Retired
nitrogamer367
so my model has 2 sides, i want to do that to both of the sides
davebYYPCU
Go to Surface Area, use Loft tool, and select 1 to join to 2.
To make a solid area under neath this surface, you can now use it to be a split body cutter.
Restore the end plate to full solid with Press Pull, then cut the excess off with the cutter, for the other end was easy to split the model in half, mirror the finished end to the other end, and combine join back up.
File returned....
