How to combine components
Message 1 of 10
I'm tired of seeing this massive list of components on the side and having to figure out which ones belong to which item, especially since I need to copy them over and over. How do I combine mulitple components into one or at least put all the individual components into their own folder?
Replies (9)
Message 2 of 10
LMD001
Hello mr.michaelrader,
You can create a new component and add the components, you like to keep together, to this new component.
Here is a little Screencast: http://autode.sk/1Yqpq8i
Hope is of any help.
Best regards,
Ludo
Message 3 of 10
markevans36301
I always appreciate someone giving an answer before I have to ask it. This was just what I was searching for
Message 4 of 10
Hello Ludo,
I tried your method, but, for some reason simple drag & drop of components doesn't work for me?
Here's my screen recording: https://gyazo.com/cf3d809d0d4eef6404fa3142b0c57d96
Working on version 2.0.4126 here.
Radek
Message 5 of 10
LMD001
@Anonymous
Hello Radek,
For the moment I have no access to a computer and only very limited access to the internet so I’m not sure why the grouping of components does not work for you. Next monday (11/06) however, I will be back home, and check this.
Sorry for not being able to be more helpful to you at the moment.
Best regards,
Ludo
Message 6 of 10
HughesTooling
@Anonymous You cut off an import part of the screen in you animation, the timeline. Is the timeline marker at the end, if it's rolled back you can't drag components like you're trying.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 10
LMD001
@Anonymous
Hello Radek,
Mark was absolutely right (he usually is) about the timeline marker. Make sure it is positioned at the end to group components.
Best regards,
Ludo
Message 8 of 10
Thanks!
It didn't work for me somehow.
What actually helped was to turn off the whole timeline. It was a final
stage of the design so I didn't matter that much.
​Cheers,
Radek​
Message 9 of 10
jeff_strater
the rules around when you are and are not allowed to restructure components (to drag components into a parent component) when in a parametric (timeline) design are somewhat obscure, unfortunately.  It has to do with what cross-component relationships exist between the components being reordered.  If your components are completely independent, (and the timeline marker is at the end) you should be able to restructure.  And, as you found out, there are no such limitations in a direct model.
Jeff Strater
Engineering Director
Message 10 of 10
danieltbarry
Community Visitor
Community Visitor
Bro.. you just made my day. I thought it was just random when I could or couldn't move bodies or components. Thank you!
