How to Combine A LOT of Lines into One???
Fab_Things
Message 1 of 29
Fab_Things
The sketch I am working on has about a bajillion individual lines (splines) that I would like to combine into more meaningful segments. It seems like a very simple operation, but I cannot figure out how to do it despite a lot of internet and CAD forum searches.  Does anyone know how this can be done?
Replies (28)
Message 21 of 29
TrippyLighting
@Fab_Things wrote:
@TheCADWhisperer
... Problem is, there are other stl files I need to go through the same exercise with.  I...
Can you explain what the ultimate goal of the modifications is?
What modifications do you want to perform?
Is a mesh file acceptable as the output?
Message 22 of 29
Fab_Things
Thank you for working on this Mark @HughesTooling !! 👍
Message 23 of 29
Fab_Things
Thank you @TheCADWhisperer !  I will look through this file and work on editing the face groups...
Message 24 of 29
Fab_Things
@TrippyLighting
The goal is to ultimately scan auto parts that are no longer in production and modify them for enhanced performance that will then be made via CNC and/or welding.  The mesh files would come from handheld scanners, which typically only output mesh files.
Message 25 of 29
Fab_Things
@TheCADWhisperer
How do I remove the big gold sphere?  I tried splitting it but it says the sphere doesn't overlap the other object.  But, it doesn't let me select the sphere and delete it... 🤔
Message 26 of 29
TheCADWhisperer
@Fab_Things wrote:
@TheCADWhisperer
That is an anomaly.
I would go back to the original stl and experiment with editing the Face Groups before converting to solid. Also, I did not run Repair before Generate Face Groups.  Might try a Remesh too.
I think a better result can be obtained, but probably not a “perfect” result.
Message 27 of 29
MichaelT_123
Hi Mr Fab_Things,
You are facing ... a common dilemma.
Fixing an overpopulated sketch by pairing points is certainly the first thought ... but think ... they might create another one in the middle. Such process is used by many semi-intelligent scanners ,,, and not only ....
Occasionally, it might be quicky but not necessarily beneficial in the long term.
In your sketch, click on 'white' points and merge them by applying coincidence constraint (sketch39)
What is the alternative? Apply intelligent measures and organize/under-populate the object. Redraw the sketch, which, in your case, is quite simple. When you look at emerged dimensions and symmetries, you will be pleased! (sketch40 ... unfinished)
Regards
MichaelT
MichaelT
Message 28 of 29
Fab_Things
@TheCADWhisperer
I will try the Repair and Editing Face Groups... thanks!
Message 29 of 29
Fab_Things
@MichaelT_123
Thanks Michael!  I will review the file you shared to help educate me some more on this topic 👍
