How to coincident a spline or point to an interection line?
I'm trying out Fusion 360 to see if it can replace Solidworks. With this loft surface attempt, I first created an intersection line with two sketches and two addition splines for them to be used as guide rails. But I can't figure out how to coincide loft profile spline or point to the intersection line.
In Solidworks, you just select a spline or a point of loft profile sketch and intersection line (projected curved in Solidworks), then add a coincident relationship.
How is it done in Fushion 360? Thanks in advanced.
laughingcreek
did you draw the profiles before or after the "intersection"line.  if the intersection line came first you would use "project/intersect" (same as pierce in sw) to get a point in each sketch you can use to coincident to.
might need to post your model for more ideas.
jhackney1972
Could you please attach your model so one of the Forum users can try and answer your question.
John Hackney, Retired
LeonardoBN
Hi @Anonymous.
If I understood right, you could activate one sketch you have, use Sketch/Intersect with your top curve. Then you can add a coincident constraint.
Starting point.
After Intersect. Here you can apply the constraint you want.
Leonardo Brunelli do Nascimento
Chemical Engineer
Profiles were created after intersection curve. Yes, project/intersect works beautifully. Thank you.
Here are two project files.  One is the question, the other one is resolved example. Maybe other new comers will find these helpful. Thanks.
