how to change units in properties ?
I want to change weight/ voliume units in properties.
now it in g , but the things in ton
also , why can't made  properties window staying at there all time , and it will change to show what body bring hight light ?
 can  Simulation report list each bodes weight ?
Ichiro.W
Did you look at the following thread?
  Properties in kg
However, it can not change the unit of PROPERTIES in ton.
Properties window is not always displayed.
Please select each body in the browser to check properties, and the highlighted body indicates which body is selected. Does this answer your question?
Do you want to list each bodies weight of any Simulation report?
As far as I know, Simulation in Fusion doesn’t have feature to list weight of the bodies at the moment.
Please let me know if you have any questions.
Ichiro Wakita
Support Specialist
Technical Support
Autodesk, Inc.
yes , list weight of the bodies , and easy to find all the weight/volume of same material is very useful .
as it is the base info to find the total material cost and shipping cost when design .
