Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to change the diameter of a hole using 2D sketch on a body.
2 REPLIES 2
dimitrikaramazovNQHKD
222 Views, 2 Replies
Can you tell me how can I change the diameter of the hole and the deepening using just 2D sketch, not direct modeling in the model that I attached in this post?
Thank you !
2 REPLIES 2
Why?  Why would you want to limit yourself to using a sketch (plus, I assume, Extrude?).  Looking at the design, it would be difficult, I think.  You might be able to enlarge these cylinders:
with a sketch + Extrude Cut.  But, you could not make them smaller.  Offset Faces works fine.  Why not use that?  Why make it harder for yourself?
Jeff Strater
Engineering Director
Thank you for your reply, I will use Offset Faces, I just thought it would be better to use 2D sketch and then use Extrude Cut,I am mostly working on 2D skechtes, that's why I asked my question.
