How to change shape/add curve to whole structure?
Hi
I have made a basic design for a passerelle/walkway. I have done this by sketching the front face shape, extruding that to 3000mm and turning it into 5mm thick shell.
Is this the right way to go about this??
I now want to add 100mm curve over the length (staying flat across). I have been experimenting with T-splines. Learnt a lot but not how to add this curve.
bob_holland
Autodesk Support
Autodesk Support
@Anonymous
Thank you for your question.
Being that I have no history as to how you created this part, this is how I would build it.
I would design it using a Sweep with a profile and path (Spline).
I would then shell out the bottom.
With this you can go back and adjust the path if needed.
Please give this a try and see if this is what you are looking for.
Thank you for using Fusion 360.
Bob Holland
Autodesk Product Support
bob_holland
Autodesk Support
Autodesk Support
@Anonymous,
I have create a small screencast showing you how to create a sweep.
And then shell your resulting passerelle.
https://screencast.autodesk.com/Embed/Timeline/46a5a605-013a-4849-b898-12f23c404bae
Please let me know if this is not what you are looking to do.
Thank you again for using Fusion 360.
Bob Holland
