- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there!
How can I change the number of sides of a drawn polygon,
select (and move) a polygon in one piece,
change the size of a drawn polygon,
ad a polygon to an existing (rectangular) pattern?
I have drawn a circle and made a rectangular pattern with it.
Around the circle I drew a 7-sided polygon, centered with the circle.
Now I want to change the size and number of sides of the polygon and add the polygon to the pattern.
I can change the polygon size by adding a dimension of course.
But when I right-click on the polygon icon, there's no option to change the parameters.
This would be very handy.
When you draw a circle, an instant dimension is created. Why not for polygons?
When I right-click the pattern icon I, then there's an option to change all parameters, but I can not add the polygon's geometry.
Another problem is that in this case the pattern and polygon icons are placed on top of each other, and therefor very hard to select.
Can you help me out?
Kind regards,
Dennis Henninger
