How to change 6 surfaces to solid?
travis.designer.vn
Message 1 of 10
travis.designer.vn
Hi
I try to replicate this form
I intent to use small model to cut bigger model.
I try using Press Pull but It's not work.
Then I try project edge from small model to big model. I use Form model/ Loft tool to make 6 surfaces.
How can I change these surfaces to 1 Body (solid)?
Best regards
Travis
Accepted solutions (3)
Replies (9)
Message 2 of 10
davebYYPCU
1. Go to Surface section, and hide other bodies,
1 Window select all 6 bodies
3. Use Stitch command, then OK.
Might help....
Message 3 of 10
JeromeBriot
Solution #1
Message 4 of 10
JeromeBriot
Message 5 of 10
travis.designer.vn
Thank davebYYPCU, It worked
Message 6 of 10
travis.designer.vn
Hi  JeromeBriot,
It's great idea. Is 2nd solution will keep ratio? It's look like deformed.
Message 7 of 10
JeromeBriot
You're right.
Here are the next steps for soilution #1 :
Message 8 of 10
JeromeBriot
Message 9 of 10
travis.designer.vn
Thank JeromeBriot,
I did little differences, I use Scale Non-Uniform.
This is result:
Message 10 of 10
travis.designer.vn
Great idea JeromeBriot! your 3rd solution
