How to best work with a multi part product?
lazze
Message 1 of 8
lazze
I am working on a multi part product designed mostly in place in a single file in Fusion 360. I am having a little trouble understanding how to best go from here to work effectively with a manufacturer to export the different parts in multiple formats.
Any help in answering these questions will be greatly appreciated:
1. How do I most effectively export each of the 15-20 parts as both stl and iges?
2. Should I keep this as a single file, or is it better to move each part to a separate file and assemble it all again in a fresh file?
3. If 2) how on earth might this be done since many of the parts share construction drawings and history?
Sorry if I come across as totally confused about the workflow. The truth is that I am. But I would be happy to be informed!
Replies (7)
Message 2 of 8
atherisinnovations
I would like to know these things as well..
Message 3 of 8
SaeedHamza
If you are looking for exporting each thing alone in both formats, the first thing to do is to make everything a component
because you see a body can only be exported in stl format, but a component can be exported in many other formats
just go to the browser and right click the component you want to export and then hit export
now after exporting them you can upload them and insert them in a new project
Regards
Saeed
Saeed Hamza
Message 4 of 8
tyler_henderson
Saeed's reply covers #1.  Unfortunately, there isn't a quick way to export multiple components at once, so it has to be one at a time.
For #2, If you know you will want to reuse a component in multiple designs, it is better to create that component separately in its own file, then insert it into the design where you want to use it.  This creates an externally referenced component (x-ref).  You'll see this by the chain link icon next to the inserted component in the browser.  You can open that component to make edits, then it will update in any design where it is used.
For #3, If you have already created all of your components in one design then you you're only choice is to use "Save Copy As" on a component to create a new design.  Then you have to delete that component and then insert the new design to replace the original component.  At this time there is no good way to do a "save and replace" in order to maintain any existing references.  We recognize this is a gap in the distributed design workflow, so we are currently working on improving this.
Tyler Henderson
Principal User Experience Designer
Message 5 of 8
atherisinnovations
@tyler_henderson This is good to hear, as I find this is a problem for me as well and leads me to use practices that end up with me confused about which file has the master/correct version of a component..
Message 6 of 8
TrippyLighting
For the purpose of sharing data with manufacturers I would only export each part in the diffferent gemeric formats as @SaeedHamza has described.
if you've followed Fusion 360's R.U.L.E #1 your components might have dependencies but should not share construction history and other elements.
If you export your components into their own files, where those components depend on other things, these might break and create yellow warnings in the timeline in the exported file, but many things can be fixed.
It takes a little experience to figure out what to avoid.
Message 7 of 8
lazze
Thank you all!
These are great answers. I had already figured out how to export each component individually, but I found it a little cumbersome. And exporting didn't include the version in the file name, so I had to make sure to put them in a version named folder or change the file name afterwards. It would be great to have this as a batch operation some time in the future.
Fortunately, I'm not going to be depending on re-using elements as components in other files later on, so I can keep my mess in one file for now. But the tip about Rule #1 and how to compose the file of external components will be something I will use in my next project.
Message 8 of 8
MikeSmell_ADSK
Hi folks,
@tyler_henderson (Fusion UX) and I (Fusion PM) are leading the efforts on the Fusion product team to understand customer requirements for some of the workflows outlined in this thread for future improvements to the product. As part of this requirements gathering, we are doing 1:1 interviews with interested parties to learn more about how you work in assemblies and with multiple contributors. If any of you would be interested in engaging in a conversation with us on this topic, please contact us directly at michael.smell@autodesk.com and tyler.henderson@autodesk.com.
We look forward to hearing from you.
Mike Smell
Product Manager - Fusion 360
