How to assemble/animate barrel cam
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
See screenshot below for reference.
I have a situation where I need to move vertically and rotate at the same time and I cannot find the correct joint combinations to make this work. As seen in screenshot, the 2 rods move up and down in the barrels. As they move, there is s pin in each rod that follows a cam slot in the barrels. Moving down, the 2 rods should rotate 180 degrees in opposite directions as they each follow their own cam slot.
There are rotational joints at the interface between each rod and the rod cap and they work correctly. I cannot work out how to make the pins follow the multidirectional cams and there is no rotation of the rods as they move.
The slots in the barrels were made by embossing a sketch on the cylinders if that matters.
Help appreciated!
