How to align or joint a hex nut or bolt in a hex cutout/hole?
kreatronik
kreatronik
Hello to all Fusion wizards 😊,
As >edit: NOT< visible from my screencast, I jointed the hex nut and the bottom of the hole together. Now I want to also align the hex surfaces to each other.
Is this possible and how?
(The hole is slightly wider as the nut, so the surfaces can't be used.)
Thanks in advance.
g-andresen
1. i do not see a screencast
2. joints can be created with an offset
Günther
kreatronik
Hi Günther,
Thanks for the hint, I missed the "Insert" after selecting the screencast 😐But I can't edit my message, because I get an error message that some html content has to be removed from my post after I inserted the screencast.
Do you have an idea what's going on? Is this a forum bug?
Update: Apparently it's a bug with the screencasts. I can't even post it in a reply! So I just put in an image...
g-andresen
Embedding a  screencast is unfortunately a long known problem.
Please create a link  (chain symbol) to the screencast.
günther
HughesTooling
In the timeline before the joint, add a joint origin.
A joint origin has the option to reorientate its axis.
Then use the joint origin as the snap point in the joint.
Mark Hughes
Owner, Hughes Tooling
g-andresen
try this
günther
kreatronik
Thank you for your suggestions.
By looking deeper into the joint options, I found out it can be done with the mode "Between two faces" which basically is @HughesTooling 's idea, but a little easier to realize.
See attached images:Hex Nut Joint - Crosssection.pngHex Nut Joint - Cutout.pngHex Nut Joint - Nut.png
