- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, teaching myself Fusion and I ran into this issue. Building an air engine that has a set of pistons that both slide and rotate between two cylinders that are mounted at a 90 degree angle to each other. I'm stumped on how to join the piston to the cylinders so that when one cylinder rotates, the pistons slide and drive the other cylinder. I'd appreciate your help. Thanks!
