How to add rib in sheet metal components.
Message 1 of 8
i draw sheet metal part in fusion 360. but dont add rib in bend portion.
Replies (7)
Message 2 of 8
TheCADWhisperer
Message 3 of 8
CAN YOU SEND , WHICH COMMAND DO I USE ?
Message 4 of 8
TheCADWhisperer
@Anonymous wrote:
...WHICH COMMAND DO I USE ?
I used the Rib command.
But I recommend that you not worry about the Rib command just yet, you might benefit more from learning to read the feature history on the timeline.
The timeline records everything I did in the order that I did it.  The complete instructions for recreating the geometry.
I recommend that you Edit Sketch1 and recreate the sketch in a new file.  Then attach your file here for instruction on next step.
Message 5 of 8
we dont satisfy this command. after creating rib , material not deform as like press part. have any option like catia software.?
Message 6 of 8
Anybody give solution my problem.
Message 7 of 8
sam_masonHNAG
Hello TheCADWhisperer,
I have a design in which I need to create a supporting feature on the outside of the bend - rather than a rib on the inside. Do you have any advice on how to handle that requriement?
Message 8 of 8
TheCADWhisperer
@sam_masonHNAG
