- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The file is for a dashboard for a screwed steering wheel. It was custom made for an Iphone 14Pro
The file specs are the following (X152M Y72M Z18.5M)
I need to resize that 14Pro dashboard to be able to fit a display with the following specs
(length is 170mm, Height 105mm and the thickness is 11.5mm.)
I also need to make Openings/Cuts to allow space for these Buttons and ports
On the left side there's small buttons to control display. (25mm from bottom of screen to buttons cut, that cut should be 45mm, from top of the screen to cut there should be 35mm)
On the right side there is some ports, HDMI, usb-c and audio port. (there are 19mm from the bottom of the screen to the ports cut, that cut should be 36mm, from top of the screen to cut there should be 50mm)
Any tips? I'm a noob having a hard time >c
