how model this shape
sonidos_urbanos2003
Message 1 of 9
sonidos_urbanos2003
Hi I am trying to model this black cord key,
the problem is how I make the intersection of this planes to generate a solid like the photo.
what method is the best to make this solid?
thanks!
Replies (8)
Message 2 of 9
davebYYPCU
Add a block of solid oversized material, into the beginning of the timeline,
Use your planes to trim the shape with Split body command, I am presuming its tapered,
remove the outside sections,
then hide your planes,
and add fillets.
Message 3 of 9
HughesTooling
I don't think Fusion has any way to automatically produce the full spherical setback fillets on those keys. Fusion can do setback fillets but they're fixed to the same size as the fillet, I have a request here on the ideastation for adjustable setback fillets, please vote!
Here's my stab at doing what you're after using sketches, split face, the patch workspace and patch. The file's attached, all sizes should be adjustable.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 9
sonidos_urbanos2003
Hi mark!
That was I looking for, thanks for the time to make the video amazing.
as first time look like a simple shape but need some experience in the tools to do it.
thanks again
Message 5 of 9
cekuhnen
@HughesTooling@sonidos_urbanos2003@davebYYPCU
pretty spot on a directest way to do it with Fusion.
The fillet tool should be able to to it at once but I am not sure if it really could mathematically do it well.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 6 of 9
HughesTooling
Tried it in ZW3d with it's adjustable setback fillet and it doesn't look too bad if you enable blended corners.
Mark
Mark Hughes
Message 7 of 9
cekuhnen
@HughesTooling
Yesh I am not really happy with what fusion fillet with setback corners makes at all in this case.
Claas Kuhnen
Message 8 of 9
sonidos_urbanos2003
Yes @HughesTooling,
in zw3d that look very well done, that is we need in fusion 360, I hope they update this feature in the future.
Message 9 of 9
cekuhnen
Yeah the Fusion solid filet with set back is ok but not great.
Claas Kuhnen
