How make subcomponents into separate components
matthias_rendell27
matthias_rendell27
Hi I'm having a problem with trying to make a subcomponent of a component into two sperate components. I want to make 'tool box v2' and 'Tool Box Tray:1' into two separate components part of assembly
Design: https://a360.co/3TB23N5
No sure if what I'm doing is possible.
-matthias
davebYYPCU
You are halfway there, Tool Box Tray:1 exists.
Make Tool Box v2 a component, by following Rule No.1.
Start a file with 2 components, by making 2 components.
Activate each one when adding detail to each Component.
If you are talking about the body 1 in the top level component, then your out of luck it being a Sheet Metal body, cut and paste is prevented.
Might help...
jhackney1972
Is the attach model what you are looking for?  If so, this Blog Article and Video explain how it was done.
John Hackney, Retired
matthias_rendell27
I think I will start over, I've read about assemblies, components and bodies and kind of understand what is did wrong; but thanks anyway:)
