How I draw this
How I draw this
ernkla
Message 1 of 17
How I draw this
ernkla
1505061184413..jpgThis is not s
This is not solid only sketch how ı made this to solid im try hardly but how?
Replies (16)
Message 2 of 17
SaeedHamza
Use the Patch command from the Patch environment to create faces, and then stitch them to get a solid body
Regards
Saeed Hamza
Message 3 of 17
SaeedHamza
Here is a screencast to show you what I mean
If you have only lines, and no profiles ( because the sketch is in 3d ) then turn of the chain selection in the patch dialog box and select the lines you want to create a patch between them
Regards
Saeed Hamza
Message 4 of 17
ernkla
Im already do it on side but middle this is not work becose its spherical and complex this is not work in this case
Message 5 of 17
SaeedHamza
could you please attach the file so that I can try
Regards
Saeed Hamza
Message 6 of 17
ernkla
Here you are.
Good luck 😄
Note (I want 1 peace not 2 peace on top)
You wil understand this word when you drawing
 And sorry for my bed english
Message 7 of 17
TrippyLighting
Before attempting to design anything with Fusion 360 you may want to go through the video tutorials in the Support and Learning sections.
I am not sure these written documentation is available in any other language so Videos might be of more help to you.
You deleted the reference geometry that these sketch were drawn/sketched on and have 4 yellow highlighted items in the timeline.
Message 8 of 17
TrippyLighting
Message 9 of 17
ernkla
I SeratasV2 v0.pngdont want this lines becose ı will print this and how ı infill this
Message 10 of 17
SaeedHamza
Edit : use the loft between point and middle curve to make the lines you wanna get rid of 1 line, but I don't think that you can get rid of the whole thing
I'll make a screencast
Regards
Saeed Hamza
Message 11 of 17
SaeedHamza
Saeed Hamza
Message 12 of 17
SaeedHamza
Here is a screenshot that shows that you need a fillet ( in the black areas ) in order to get something smooth like this
Saeed Hamza
Message 13 of 17
ernkla
Sorry but it not work and how ı infill this
Message 14 of 17
SaeedHamza
When you say it doesn't work, do you mean you can't create or is it not what you want?
And about the fill, use the stitch command in the patch worksapce
Saeed Hamza
Message 15 of 17
ernkla
Message 16 of 17
SaeedHamza
Check this, it  will help you do it
Saeed Hamza
Message 17 of 17
ernkla
Thank you for all thats work  Smiley Very Happy  Smiley Very Happy
