How i can see, wehn my sketch is fully defined?
when i create a sketch i can't see wehn it is fully defined. I've seen an video, where the color of the lines are turn from blue to black when they are defined. My Lines are always Blue.
I've create a circle directly on the zero point of the plane and defined the diameter to 50 mm. And nothing happend whith the color of my circle.
Can you help me, to understand where i can see when the scetch is fully defined?
Thanks Andy
HughesTooling
Click your name top right of the screen then click preferences and look under Preview for Sketch - Colour sketch geometry on constrain status. It is still a preview so it isn't accurate in all situations.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark,
that was the setting, for which I was searching!
