How do you make panel lines/cuts?
t_smith5
Message 1 of 19
t_smith5
Hi
I'm a bit confused on how best to make panel lines/cuts on a mesh. Such as patterns/panels like these...
I did watch one YouTube video where the guy used Pipes, but it looks like I need edges to be in place first where they'll wind up being, and I'm not quite sure how to achieve this. It looks like they use Construction Planes, but I'm not sure how I can manipulate them correctly. The part I'm trying to experiment on is at an angle. The file has been attached below...
Replies (18)
Message 2 of 19
davebYYPCU
.... where the guy used Pipes, but it looks like I need edges to be in place first where they'll wind up being,
Correct.
Simply put - you need sketch line / curves, or body edges for the pipes / or Sweep (a different profile).
Panel lines are added near the end of the part timelne/s.
Might help.....
Message 3 of 19
t_smith5
Is there no way of adding them after a Body has been created? In the same video I saw them use Construction Planes to cut into their mesh to make the lines/edges and then by splitting, I think. I just can't seem to get them to work on the part I've been trying on due to the angle and where the lines are positioned.
Message 4 of 19
davebYYPCU
Panel lines are on a body surface, you will need a body to put them on.
You can use other bodies (edges) to run them on, instead of 3d sketch lines.
Might help...
Message 5 of 19
t_smith5
I don’t quite follow. Do you mean I should Join other objects so their edges are poking through the faces?
Message 6 of 19
davebYYPCU
Because you have mostly curved faces and bodies, the panel line tracks can be done with
"To Object " construction.
Best to use a circle profile and then orientation is much easier.
Your file has multi colour panels, and you will be split faces for those, panel lines can go on the same edges.
Might help...
Message 7 of 19
etfrench
Create the outlines in a sketch. Use the outlines to cut the face of the model.  Use those as the path for pipes or sweeps.  Emboss would also work, but only on plane or non-compound curved faces.
ETFrench
Message 8 of 19
mukhopadhyaysayak
I am doing it by extruding the profile sketch as a surface, splitting the body, slightly bevelling the edge and joining the body back.
The only drawback is that making any changes in the history before the split has the potential to break the model.
Message 9 of 19
g-andresen
Create the paths for the pipes with Split Face.
(view in My Videos)
günther
Message 10 of 19
g-andresen
The "Split Face" function does not split bodies, but only selected faces of bodies.
Multiple splits can also capture multiple faces with the same profile.
(view in My Videos)
günther
Message 11 of 19
t_smith5
Perfect. Thank you so much for this. I always prefer it when someone uses a visual guide or video on how to do something. 😁 I'll give this a try and see how I get on. If I have any questions I'll report back. 🙂
Message 12 of 19
t_smith5
Okay, one question I have: how do you have the Control Point Spline at the top, above Create? I have to go through the Create menu to access it.
Message 13 of 19
t_smith5
Okay, I would be awkward... 😅 I've decided to go about the pattern cuts differently. I want to replicate this design as I much prefer it:
I've tried adding a circular line/cut around the one at the front, but the Split Face isn't doing the job quite right, and I'm not sure how to approach it properly. This is the Sketch I currently have:
I did try flipping the mesh the right way up so it was no longer at an angle, but now I can't seem to manipulate the points of the Sketch like I was able to before. 😕
Message 14 of 19
g-andresen
just take a look at sketch "profiles".
There I have "coupled" some control points in the vertical.
günther
Message 15 of 19
t_smith5
How did you manage to get those areas coloured? Were they just given a random material?
Message 16 of 19
g-andresen
enable faces
günther
Message 17 of 19
t_smith5
Sorry, but I'm still fairly new to Fusion. Where's that option? 😅
Message 18 of 19
g-andresen
Rightclick Body >
(view in My Videos)
günther
Message 19 of 19
t_smith5
Perfect. Thank you. 😄
