How do you make angled offset construction plane?
hungddngo
hungddngo
I am still fairly new to this but am finding out ways to slowly chip at the object I want, very tedious I might add.  Just wondering though.  How do you go about making angled construction planes or a construction plane that is in the middle of an object?  I feel like having these types of basic knowledge would allow me to make my cuts better.
Thank-you,
daniel_lyall
@hungddngo wrote:
  How do you go about making angled construction planes. by useing a plane at angle or a tangent plane
the plane at angle is just click on a line and set the angle if you wont it 90 to something you turn the origin on and use one of those planes to set the angle
tangent plane is click on something round and set the angle the same way you do the plane at angle
This is midplane what is click on one side of a object then click on the other side of a object and a plane will be in the center between the 2 spots clicked on
If you click on construct then hover the cursor on a plane, what it's purpose is will pop up in a pop up.
All this info is in the support & learning above or here http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2AABB91A-0E9E-4D28-8D3C-EAFEE93B32A0
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
