How do you set constraints/parameters so that sketch geometry will resize itself when a text feature is changed?
I tried to make a parametric box on the bottom of a line of text to join the letters together (for 3D printing). I used a collinear constraint to get the end of the box in line with the bounding box of the text. However, when I change the text, the rectangle is no longer collinear with the bounding box of the text.
Screencast here: https://autode.sk/2lHs4tc
It seems like the text is recreated from scratch and loses all constraints every time it is edited.
Is there any way to get the model to resize with the text so I don't have to manually resize it every time I change the text?
5a4eb85a-7e12-4009-89fe-aa3cfcc66cb4
