How do you get geometry to resize itself with text (i.e. parametric text)?
LMF5000
Message 1 of 8
LMF5000
How do you set constraints/parameters so that sketch geometry will resize itself when a text feature is changed?
I tried to make a parametric box on the bottom of a line of text to join the letters together (for 3D printing). I used a collinear constraint to get the end of the box in line with the bounding box of the text. However, when I change the text, the rectangle is no longer collinear with the bounding box of the text.
 Screencast here: https://autode.sk/2lHs4tc
It seems like the text is recreated from scratch and loses all constraints every time it is edited.
Is there any way to get the model to resize with the text so I don't have to manually resize it every time I change the text?
5a4eb85a-7e12-4009-89fe-aa3cfcc66cb4
Replies (7)
Message 2 of 8
jeff_strater
You are correct - apparently, constraints/dimensions to the bounding box of a text object seem to not get preserved when the text is edited.  For now, there does not seem to be a workaround.  I'll log that bug.  Thank you for reporting it.
this bug has been logged as FUS-41321
Jeff Strater
Engineering Director
Message 3 of 8
LMF5000
Thank you Jeff, that's great to hear 🙂
Message 4 of 8
daryl_stamp
Defining text height as a parameter looks like it is intended to work, but it doesn't.  That is, text height can be set to a parameter value (it accepts the parameter), but changes to the parameter have no effect.  Can you add this to the 'bug list' for future corrections?
DLS
Message 5 of 8
untrustedone
i was going to make another entry, but for now i just liked. Amazing that search works.
Message 6 of 8
klack107
Observer
Observer
Any updates on this?
Message 7 of 8
Arthur_Hebert
Fusion 360 added more text functionality. I think the question needs to be checked for what problems still exist and reposted.
example of a quick internet search:
New Fusion 360 Features: Text on a Path, Text Frame, and More_October 29, 2020
Message 8 of 8
I might not fully understand the featureset but I'm having a similar issue.
I am making custom keychains with people's names.
I would like to constrain my drawing so that as I put in different peoples' names, the length of keychain changes.
It seems like
1. The textbox length doesn't automatically change with the length of the actual text in the box
2. If I try to constrain the length based on how much buffer space I want to the left and right of the text, Fusion complains that the drawing is overconstrained (even though there are no other constraints on the length.
