How do you delete Coincident Constraints?
scottmoyse
Mentor Mentor
Message 1 of 29
scottmoyse
So how do you delete the coincident constraint between two rectangles? or even between two line segments of a rectangle?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Replies (28)
Message 21 of 29
daniel_lyall
@scottmoyse wrote:
@jeff_strater To be honest, the way Inventor handles constraints across the board in the sketch environment is excellent now. It wasn't pre-2015 but they've really nailed it now. F8 & F9 toggles constraint displays (based on constraint display settings) and as soon as you select any sketch object it's constraints appear. If you window select objects, again all their constraints appear. The relax mode is epic as well!
When it comes to reviewing this lot, have a good look at Inventor 2016 sketch constraints. I'm sure you would anyway.
I would say yes please to that
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 22 of 29
It would be very useful if coincident point were color coded. It is often hard to tell when I connect multiple lines to the same end point if Fusion has automatically set a coincident constraint.
Message 23 of 29
simon.dyer
Is this a bug or a newbie error?
I cant change the size of this rectangle - I want to bring the top down.  It seems to be constrained but nothing Ive tried will let me change it.
Message 24 of 29
Oceanconcepts
It looks as if it might be constrained to the line across the top. Can you delete the right angle constraint that shows at the top right in your picture?  Highlight, press delete.
- Ron
Mostly Mac- currently M1 MacBook Pro
Message 25 of 29
top line might have a fixed constraint henc the pink color. Also try removing top right perpendicular constraint as mentioned above.
Message 26 of 29
simon.dyer
I cant select any of the contraints,as shown in second picture.  Right clicking over the constraint does not display a 'remove constraint' option
Message 27 of 29
simon.dyer
Okay - apologies everyone - newbie error -  the selection filters were mostly unchecked. Now its working
Message 28 of 29
simon.dyer
ok off topic but related to the same model
why is my selected sketch extruding as an earlier version of itself?
Message 29 of 29
simon.dyer
ooops its okay, when I hit okay it completed the modified shape
