Sketch mode bug: invalid second solution for midpoint constraint on arcs
The screencap below should pretty much speak for itself.
martin.zatecka
please would you describe how did you make the midpoint constraint? I wasn't able to reproduce it.
thank you in advance
Martin
Martin Zatecka
UX Designer
Hi Martin,
Here's an F3D file with a sketch that exhibits the behavior. Grab part of the arc on the bottom and drag it up and down; the location of the midpoint constraint should jump back and forth between the proper solution and the "other" one, seemingly at random.
martin.zatecka
Hello Greg,
It is interesting catch, when moving fast up it happens every time. It is nice bug, we are going to fix it.
Thank you
Martin
Martin Zatecka
UX Designer
