How do you cut an object using two different splines?
tim_reinbold
tim_reinbold
I want to cut a shape out of this cube, which is made out of two different splines, but I don't know how you would call this action and therefore cant find any tutorials on it.
davebYYPCU
Go to Surface area.
Create > Loft - one curve to the other.
Split Body > Select the solid body, then select the surface body from the Browser,
you may have to tick, extend Tool, > Ok.
In the Browser, Select the offcut body, then Right Click and Select Remove.
Might help....
TheCADWhisperer
@tim_reinbold
If you want both sides then Split Body instead of Replace Face.
g-andresen
try this
günther
tim_reinbold
Thank you for your answer, the loft tool was exactly what I was looking for, but I used the tool from the solid area to cut out part of the block.
