@Anonymous wrote:
Fusion's approach: Right click, select "Sketch Dimension", place the dimension, click, enter diameter, Enter, right click on newly added dimension, Delete.
EIGHT steps.
Nope. Read MESSAGE 14 again.
@Anonymous wrote:
Why there isn't just right-click, choose "Edit", enter the new diameter?
There is a double-click on the dimension, enter the new diameter. No more steps than what you propose. Don't even have to click an Edit button or anything.
@Anonymous wrote:
With a body like a box, I get that edit option in the context menu.
Now you're talking about Fusion's Primitive bodies. I'm not going to go into WHY you should avoid them here, but you should.
@Anonymous wrote:
And exactly at this stage, Fusion does it's best to hinder the process of quickly setting up a sketch.
Any sense in that? - Just go ahead, tell me. I'd be happy to be proven wrong, also happy to learn.
You only find the process hindering because you're inflexibly demanding to have it your way. The way Fusion does it differs from your proposed way, but it isn't any harder or any more steps. If you've watched a few of the beginner sketching tutorials, and still feel a lack of confidence in a particular area, I would be happy to make you a custom video answering your question(s) and/or showing you how easy it is.
@Anonymous wrote:
But I just don't wish dimensions to be displayed.
And in that case, editing a simple parameter like the diameter becomes a senseless act: Displaying dimensions again, editing, hiding dimensions again. Now show me a tutorial telling me how to change a circle's diameter without using dimensions display.
Well, I really don't understand why you don't want them displayed. They, along with constraints, are the lifeblood of the sketch. But, if you must, I would point out that you can use the Parameters dialog to change any dimension value. You can even make often-changed values into Favorites or User Parameters so they will appear at the top of the list. But even if you don't want to do that, the process of "displaying dimensions again, editing, hiding dimensions again" isn't really any more work than "right clicking, clicking an Edit button or context menu item, editing, exiting the Edit dialog."
Look, I get it. Quite often I use some software and think, "Why the heck did they do it like this, when doing it this other way is better?" Yes, that has even happened using F360.
But here is the reality: Every person in the world doesn't think exactly the same, including you, me, and the Autodesk developers. We voice our opinions, they try (painfully slowly it sometimes seems) to feel out the majority user consensus (if one can be discerned) and make changes/improvements to their software appropriately. Not every user is going to be satisfied in every little way. As a user, if you find the software useful enough versus the price of it, it's best to voice your opinion in the Idea Station forum, and in the meantime just make the tiny, tiny effort required to adjust yourself. I mean, the time you've spent whining about this so far, honestly, is more time than you will waste leaving dimensions on and using them as intended, compared to your proposed way, over twenty years of use.
Personally, I can't imagine turning dimensions off. I would turn them back on immediately and wonder who had been Effing with my computer while I was in the break room! I mean, suppose you had a shape like this... How would you edit this via a properties dialog or whatever? You can't just right-click on the '3' sketch, choose edit, and type a value. Just editing the value in place is MUCH more intuitive, and quick and easy.
