How do I wind and unwind a flat coil spring?
pranav97jain
Message 1 of 16
pranav97jain
Hello Everyone,
I'm working on a project and I want to use a flat coil spring in it. So, I want to know how can I simulate the winding and unwinding of a flat coil spring.
In the figure above, I want the coil to wind when the rod rotates clockwise direction and unwind in the opposite.
I'm using this in a counterweight assembly to provide an additional spring force to keep the system balanced (would like to know your thoughts on this or if there are any other solutions that can be used instead of using a spring).
I also want to know how do I create a string between two blocks that will work in a simulation?
Replies (15)
Message 2 of 16
TheCADWhisperer
You will need Autodesk Inventor Professional for that functionality.
Animate Parameter.
Students can get 1yr (renewable) learning license of Inventor Professional for free from the Autodesk Education website.
Did you put realistic clearance for your slide blocks (I can’t see in image).
Message 3 of 16
mango.freund
Message 4 of 16
TrippyLighting
That method does not apply to this spring because this spring is a spiral (variable radius)not a helix.
That method has been posted many, many years ago and multiple times since then on this forum.
Message 5 of 16
mango.freund
Hallo @TrippyLighting , peter denkst du wirklich der gute mann kann die spirale nicht schneiden und den drehpunkt fuer sich guenstig anlegen? dann waere es natuerlich traurig. 😀 lg mango
Message 6 of 16
TheCADWhisperer
@mango.freund
Ich glaube nicht, dass Sie die eigentliche Frage, die gepostet wurde, lösen können.
Can you File>Export your "solution" *.f3d file to your local drive and then Attach it here to a Reply?
Message 7 of 16
davebYYPCU
Is there a translate button?
I couldn’t find the right words so just I shut up.
Message 8 of 16
mango.freund
Message 9 of 16
davebYYPCU
Thank you,
can you show us?
Message 10 of 16
pranav97jain
I've attached the F3D file.
Sorry for late reply and thanx for helping me out. 😃
Message 11 of 16
pranav97jain
I just downloaded the Inventor. 👍 will try to work on it now... 😄
Message 12 of 16
TheCADWhisperer
Uhmm, it will take several years of training/experience...
Inventor is a professional program and deserves (requires?) a professional level of preparation. 🎓
Your Sketches are not fully defined - this is usually covered in the first 10-30 minutes of an Inventor class and should be mastered before moving on to Animation of Parameters and/or Dynamic Simulation.  Where are your dimensions?  Are you just "eyeballing" this to the grid?
There is not clearance for these slide blocks in the slots - so the mechanism will not work in the real world.
Is it your intention that this cylindrical rod remain stationary - or do you intend for it to revolve?
(There is no Joint that would answer this question.)
Message 13 of 16
pranav97jain
Thanks for pointing out the mistakes (I'll need some more practice 👍).
Well, it was an idea that I wanted to try out.
Message 14 of 16
TheCADWhisperer
Your geometry is pretty simple - concentrate first on how to fully define sketches.
Ask questions when you have blue lines rather than black lines (actually the colors depend on your environment settings) - but you need to dimension your sketches.  That is the foundation of all other work.  You don't want to build a house of cards on a foundation of sand.
Message 15 of 16
pranav97jain
Thanks for your advice.. (Nice Analogy 😄 though).
And I'm currently making a model and trying to apply proper dimensions and everything...
Message 16 of 16
TheCADWhisperer
@mango.freund wrote:
Hello @TrippyLighting, peter do you really think the good man can not cut the spiral and put on the pivot point for himself cheaply? then, of course, it would be sad. 😀 lg mango
(Translation from Google Translate)
@mango.freund
Still waiting on your "solution".
I am sad that I cannot figure out how to do it in Fusion 360.
