How do i turn off all keyboard shortcuts?
sking772QM
sking772QM
How do i turn off all keyboard shortcuts? TIA.
jeff_strater
as far as I know there is no easy way to do this.  There is probably an XML file somewhere that you can edit, but I'd have to look that up.  The only way through the UI is to manually find each shortcut and edit it, leaving it blank to disable the shortcut for that command:
Jeff Strater
Engineering Director
rushabhthakkar_910
I don't think there is a way to do that currently... But maybe in near future there will be one...
I saw on Fusion 360 Blog....
Is there a way to see all the custom keys I have set instead of individual ones?
  • Not yet, but we’re working on it as phase 2 of this project.
What else are you doing for Phase 2?
  • We’re working on giving you keys for display setting > visual style, keys for view-cube views, and better ways to share your custom keys with your team.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
