I'm trying to design the neck of a soap dispenser. I found the spec in the 4th page of this document: https://www.thecarycompany.com/media/pdf/specs/68W26B.pdf. I created the thread, but it starts and end on a wall, not a smooth transition from the shaft:
How can I make it start smooth, emerging from the central shaft?
Here's my model: https://a360.co/3r2JSAK
Solved by MRWakefield. Go to Solution.
The way I do it is this:
See attached.
Hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
