How do I scale an imported object/component
Message 1 of 8
I designed an electronic commercial product and imported certain objects, like well designed speaker cone into the body. However, the imported code is too small and I can't seem to be able to scale it larger. Is the imported component locked or what am I doing wrong?
Replies (7)
Message 2 of 8
TrippyLighting
Does this not work ?
Message 3 of 8
Yes, I am unable to select the cones to scale through the route. All the local components are selectable for scaling, except the imported speaker cones.
Message 4 of 8
TrippyLighting
Lacking any other information, I am aassuming that you are trying to scale linked components within the assembly they've been inserted into.
That does not work.
Simply break the link. Then you can scale them.
Message 5 of 8
That was correct, right clicking the component and breaking the link did the trick. Thanks
Message 6 of 8
MartinMajewski
However, as it seems only positive scaling is possible. Shrinking objects down in size is not allowed?!
Message 7 of 8
HughesTooling
You can scale down, just enter a scale between 0 and 1. So a scale of 0.5 will half the size of an object. If you are trying to scale using a minus number the part will  end up a mirror image. If you want to use a minus scale you need to add the scale using a positive number then edit in Parameters from the modify menu.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
nicoandres106
Community Visitor
Community Visitor
Thank you so much!
