Message 1 of 9
- Mute
- Permalink
- Report
I have searched for answer but have not found a solution. I am trying to rotate a sketch grid or sketch plane so the horizontal or vertical axis would align with some other angled geometry or feature instead of with origin HVD. I do not want to have to rotate the component or body because it may be part of a much larger assembly. It will also cause issues if I need to sketch in a different plane. Is there any way to align the sketch grid with a different HVD than the origin? In the linked screencast I want to draw a rectangle that is parallel to the hypotenuse of the triangle.
