How Do I Remove This Edge?
ryanasher1998
ryanasher1998
How do I remove the edge highlighted blue? Basically what I'm trying to do is make the tab and main part of the body one face. Using the merge feature doesn't work. I have tried simply right clicking it and deleting it but that does nothing.  I was able to delete the opposite edge on the outside of the tube but not the inside. I don't even know how I did that to be honest...
I'm very new to Fusion. This is a customer's file, I did not make it. I believe it was made in Solidworks.
Also, does anyone have recommendations/resources for learning Fusion specifically for tube/pipe fabrication? Looking to learn how to build hand railing, roll cages, etc. Mostly with round and square tube but occasionally I'll be working with rectangle tube, L channel and U channel as well.
wersy
Here are some videos
https://www.youtube.com/watch?v=pSdN5J8c8l4
https://www.youtube.com/watch?v=pNVSiTv4_c0
https://www.youtube.com/watch?v=AH3QWscviBc
laughingcreek
when I select this face and delete, it seems to work ok-
HughesTooling
@ryanasher1998 After importing a STP file you might want to enable history, then if something like this happens we can figure out why.
I guess you had a sketch at some point and deleted it?
Mark Hughes
Owner, Hughes Tooling
ryanasher1998
I will try enabling and take a look at it. I didn't make this file. A customer sent it to me.
ryanasher1998
Weird. It wouldn't work for me, but I reopened the file and it worked. Thanks!
