How do I remove the radius on the inside of this bowl?
oxbydandm
Message 1 of 9
oxbydandm
Hi everyone, I have designed a bowl which is curved on both the outside and inside. How would I go about making the inside walls and bottom of the bowl meet at 90 degrees while keeping the outside curve? I am trying to do this in order to improve running times. The bowl was made using forms I then thickened the resulting shape to create the bowl. I will attach an image below to show what I mean. Any help is greatly appreciated.
Thanks, Tom
Replies (8)
Message 2 of 9
davebYYPCU
Revolve an inner profile to suit.  If not completely round, use Sweep with that same profile.
Could have Revolved / Swept the whole thing - didn’t see anything to require a form version.
Might help....
Message 3 of 9
TheCADWhisperer
@oxbydandm wrote:
…was made using forms I then thickened the resulting shape to create the bowl.
@oxbydandm
Why did you use complex Form rather than simple Revolve?
Message 4 of 9
g-andresen
without words
günther
Message 5 of 9
davebYYPCU
I don’t think either of those suggestions will work out on this bowl, there is no apparent internal ring to crease.
@oxbydandm careful what you wish for, you may not have enough wall thickness after cutting the inside away.
Might help....
Message 6 of 9
oxbydandm
Hi, would you be able to expand any further on how I would do this. Which part of the inside to I select to revolve
Message 7 of 9
TheCADWhisperer
@oxbydandm
Message 8 of 9
TheCADWhisperer
@oxbydandm wrote:
… in order to improve running times.
What manufacturing process?
Lathe. Milling machine. 3D Printer?
Message 9 of 9
oxbydandm
Hi everyone, thanks for your help. This issue has now been resolved.
Thomas
