How do I print out a sketch?
Message 1 of 256
Hi all,
What's the best way to go about printing out a sketch on a regular inkjet printer to scale?
Replies (255)
Message 221 of 256
kowalski_
Community Visitor
Community Visitor
 dieselguy65  -  said "There's absolutely zero need to print a sketch in 3d modeling. And you'll continue to not get it."
How did i find this forum??
I created an object that has to be hanged on the wall. it have some irregularly spaced holes so i fugured out i will print sketch and place it on wall and drill holes in exact position they sould be.
But I can't because some guy in Autodesk with god syndrome isn't smart enough to finally understand it after 11 years of explaining that a given functionality is needed by USERS. This programmer made a decision that this functionality is not needed and he doesn't care what those who pay for it think about it. If he says you don't need this functionality, then you don't.
Congratulations on your professional approach to the customer.
So dieselguy65  is it really not needed?? Maby for you but not for me.
@kowalski_ - this post has been edited due to Community Rules & Etiquette violation.
Message 222 of 256
laughingcreek
fyi-dieselguy doesn't work for autotdesk.  just another forum user like yourself.
not everyone agrees that it's not necessary to be able to print a sketch, including programmers at autodesk.
the reason it took so long was a matter of priorities set by the programmers bosses, not that it wasn't necessary.
the ability to print a sketch has been implemented.
Message 223 of 256
RA_Nouveau
You can export a DXF I think..
I just make sure I am in white background mode vs dark mode. Then use Greenshot to take a screenshot. Fusion has a screenshot option also. I use this as a running notebook method as I am not a pro and I use paper and pen for the art as well as fusion, inkscape, blender, and some other programs. "WHat was I doing in what file....." Mask Test 1v3....V20.....what file was that in....." 🙂
I also use SVG export for templating all the time like you do. Or to go to the laser. I bought a 11x17 inkjet partially for this reason, or I tape papers together. I know a guy with a print shop that can go much larger if when I need it. Art classes love 18x24 paper.
Or I get the basic shape right in the drafting program, print and then use tracing paper and art supplies to make it less "Sterile." Then back into inkscape and blender then fusion (for CAM)  I feel I make "Good math homework" but not "art" yet. Nature is not all G2/G3 surfaces.
Print, rubber cement and to the drill or the bandsaw, or 2x tape, etc. For hogging material before the CNC this is a great option.
Take what you can from the people here and ignore the rest. There is one guy who's math related work is amazing. 🙂
Example of one of my pieces: Started as a sketch, and then back and forth in and out from paper to cad to cad to cam.
Message 224 of 256
dieselguy65
Are y'all still on about this?
3d modeling software doesn't need to print a sketch. It's not 2d cad, or
sketchup. Lol
Use it for what is intended purpose, 3d modeling.
If you have just a little background in cad. You will understand why a
sketch need not be printed......
Instead of using the right software for the job
Brian.
@dieselguy65 - this post has been edited due to Community Rules & Etiquette violation.
Message 225 of 256
RA_Nouveau
 I hope as my skills continue to improve that I end up with the kindness and patience of @TheCADWhisperer  when working with new people.
@autodeskmod is this the tone you want your customers to see when they are starting out?
Especially for student use where we have to show our work in a stepwise fashion due to plagiarism, or paying someone to do our projects. I said previously I export to SVG and DXF at times (one of them ls locked out in the "Free" version.)
This includes the sketches so that the professors can see that we did our own work since there is "More than one way to do it."  This was for "2d design"
@kowalski
Here are some ideas. I'll elaborate on how I did this if you want.
This was done in a combination of fusion, and inkscape. Then cut out on a trotec 400. The class was called 2d design so my 3d design was flattened in a sketch....so I could export it (AKA PRINT IT OUT) and then put into the Laser as an SVG.
https://www.instagram.com/p/DEa7FQIyt5P/?img_index=4
I detailed some very good uses that I apply frequently in my art projects.
I started in 3d https://www.instagram.com/p/DEa7gbTyM3l/?img_index=4
Then projected into 2d to get all the tracery lines: https://www.instagram.com/p/DEa7gbTyM3l/?img_index=2
Then exported the sketch (AKA PRINTED IT OUT) in SVG to import into Inkscape. So then the laser could handle it.
I used multiple SKETCH LAYERS to then set the colors on the vector lines which then tell the laser which speed, power, and focus depth to use. (Because it's just another CNC)
The final part I ran out of time for was to then also take the piece off the laser with locating pins and then use a v carve bit on the edges for details more like Waterford cut glass.
Here I set up the initial geometry for the roses in Fusion see the Dard Rose File PDF;
Fusion to do the setups, way too many pattern on path, then flatten with a project sketch one per sets of lines and export as PDF and out to inkscape and the laser. This is a privacy screen for my window.
@RA_Nouveau - this post has been edited due to Community Rules & Etiquette violation
Message 226 of 256
RA_Nouveau
PS. It is amazing what I see people do in this software, and it is truly a blessing that we all have machines that have vector processors of  supercomputers in the 90's and more ram then servers of the 2000's on our laps.
We live in the future!!!
Message 227 of 256
jmvannoy
That's great news!  I look forward to trying it out.
Message 228 of 256
khankins5
It amazes me how long ago I started. I was looking for alternative to sketchup & wanted prototype patterns for cnc integration.   I saw real potential.   However such a basic thing as full scale printing "would never be needed".   While accomplished with plug-ins etc, worked.    Maybe the thread can now die a peaceful death due to old age.  Cheers
Message 229 of 256
mastertechjohnny
Never this needs to be a feature. Some people can’t afford to full CNC
every part they make. That being said if you could print things out like a
bolt hole pattern or a shape that needs to be cut by hand that would be
great. Having to go outside of fusion to use a 3rd party app like adobe to
open a .dxf file to print is just dumb. And for anyone that says your using
a 3D software… no fusion has plasma cutting and 2D milling features built
in for producing gCode to send to a 2D CNC so that argument is invalid.
This software isn’t only used for 3D CNC some of us use 2D patterns to
create 3D things on 2D machines. The last point that I want to make is that
fusion also has a sheet metal feature built into it with a lay flat feature
to get all of the parts ready for plasma/laser cuter.
Message 230 of 256
jmvannoy
laughingcreek can you direct me to the "print sketch" function?  I'm not having any luck finding it.  When I right-click the sketch, there is no "print" option in the context menu.  Thank you!
Message 231 of 256
laughingcreek
I know everybody just wants a button to directly print a sketch, but the sketch does need to be laid out in a 2d space for printing first.  that's done in drawings.
create  drawing.
turn on the sketch you want to print.
lay the sketch out on the paper the way you want.
change line types if it's not set to one you want.
print.
Message 232 of 256
etfrench
Unfortunately, this requires all of the desired dimensions to be recreated.  It does allow printing 1:1 so it is better than just using Print Screen.
ETFrench
Message 233 of 256
jmvannoy
Yes I believe that's the whole point of this thread.
Message 234 of 256
laughingcreek
when this thread was started, there wasn't  any way to print sketches.  you had to extrude something into a 3d object first and print that.  you couldn't make a sketch visible and print that.  that's the point of this thread.
Message 235 of 256
khankins5
The Genesis was to print a 2d face TO SCALE.   1:1.  noting more.
Message 236 of 256
g-andresen
Then you create a drawing, select the format, if necessary a user-defined one, and print it to a PDF.
günther
Message 237 of 256
khankins5
Printing to "scale" is issue not printing
Message 238 of 256
laughingcreek
yep.  and now you can.  before you couldn't.
Message 239 of 256
keywestboats
what freaking nonsense
Message 240 of 256
keywestboats
Print screen and edit in a photo editor. Who ever heard of a simple print command?
