You are absolutely correct John! I'll have a go myself and see if I can work it out for myself...
Meanwhile, a couple of extra questions..
I notice you have colour coded the components in the list on the left. How do you do that?
Secondly, I'm making the head from three vertical slices
I've used a head component with a single sketch for all three sub-components but I'm not sure if that is best practice, for example, I changed my mind about the circular hole in the head side, I deleted it from the sketch which deleted it from only one of the head sides. Also, for the new horizontal slot, I used a cut from the sketch to cut all three parts at once but suspect that I have moved one part slightly causing it to be misaligned. What would be best practice for such a construction. Thanks again for all your help!
