How do I join these edges?
atURDHL
Message 1 of 26
atURDHL
[edit]
nevermind... figured it out... how do I delete a post? 🙂
I know it's probably something simple but I'm pretty new to 360 & haven't been able to get this to work...
Basically, trying to model something like an ice cube tray... I want to join the "ice cubes" to the "flat tray" surfaces where the red lines are below. I will be rounding out edges and adding thickness to it later...
thanks
Replies (25)
Message 21 of 26
atURDHL
Ok, think I got it - it looks like rather than joining the shapes, the extrusions have to be done into an already-extruded form, then faces are eliminated in Surface mode.
The cool part is that I can move the existing edge geometry around to relocate the extrusion!
However, after the faces are removed (and perhaps before, not sure) it appears that additional geometry / cutting objects can't be added to the remaining surfaces.
What functions should I be reading about here? Seems like it can be done, but again, I don't know what tools / methods to use. It seems like I should be able to draw a circle on the same surface, for example, and simply delete the inner geometry.
Message 22 of 26
TheCADWhisperer
@atURDHL wrote:
Rhino, no thickness:
I think you are making this more complicated than it need be. Rhino is not the real world. Do you have a photograph (not virtual CG screen capture) of similar real world object of zero thickness?
Message 23 of 26
TheCADWhisperer
Trim.
When you can't figure something out - you should Attach your file here...
Or go back in history and Extrude.
Message 24 of 26
atURDHL
Ok - I've gotten that far & am able to remove the circle on the surface.
Next step was to create another extrusion like the rectangle... I can't find a way to remove the surface geometry after the new extruded geometry is created. Again, would be great to simply be able to select the circle (which I can) and delete it (which I can't) and then join all the surfaces.
I'Il definitely have to find some tutorials because the geometry is definitely not doing what I expect! 🙂
File attached.
Message 25 of 26
laughingcreek
I think your over thinking it
Message 26 of 26
laughingcreek
