How do I hide construction lines?
Message 1 of 83
I've been away for a while, and thought this would have been incorperated by now, but I can't see a way to do it.
Replies (82)
Message 21 of 83
adam
Please add this feature, it just seems like a simple and obvious requirement
Message 22 of 83
sanjay_jayabal
Similar to what Jesse was suggesting, I am wondering if creating an XRef component with all the construction geometry will work.  Definitely a tedious workaround, but could work.  Start with the Xref component in your design and keep adding construction geometry to the xref component (on the appropriate planes).  Depending on how much construction geometry you add, this will likely add some clutter as you will have to manage construction sketches separately in the xref but could get the job done for you.
Best regards,
Sanjay Jayabal.
Message 23 of 83
shahriarsifat1802164
If you decide to hide only construction geometry, I think there is no other way to hide it.
you just click ok, and back to select another sketch,
thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 24 of 83
There are definitely workarounds, and at the end of the day it's just a QOL change, but it feels like a pretty obvious and helpful one. I'm sure there are code components that make it tough, but the design choices seem simple, and actually considering implementing this would be incredible.
Message 25 of 83
adam
It just seems obvious that it is a required feature, I can't understand how it hasn't been implemented yet.
Message 26 of 83
siddharth.patilV3RVT
Community Visitor
Community Visitor
Please add this feature the person who wants can turn it on from settings an after turning on while in sketch view rightclick on empty space then we should be able to toggel it
Message 27 of 83
TheCADWhisperer
Can you Attach a file here that illustrates how this would be useful?
Message 28 of 83
adam
It would make selecting lines (eg, to fillet) far quicker and more convenient if you could hide the construction lines with a check box - just like you can for projected geometries and dimensions 2021-06-08 07_59_44-Autodesk Fusion 360 - 2.jpg
Message 29 of 83
TheCADWhisperer
Can you add a Screecast of the process of adding the sketch “Filets”?
How did you add a “Fillet” with a diameter dimension on the right side in your image?
Can you Attach the *.f3d example here?
Message 30 of 83
davebYYPCU
That sketch has no useful purpose for any construction lines, hide them with Delete Key.
Might help.....
Message 31 of 83
g-andresen
 maybe this way ?
günther
Message 32 of 83
TheCADWhisperer
 maybe this way ?
günther
That not a Sketch Fillet.
I wasn’t born yesterday.
Message 33 of 83
adam
It's not about filleting, the question is "How do I hide construction lines?"
It seems to be a basic and often asked for feature, which is missing from Fusion
Message 34 of 83
TheCADWhisperer
@adam wrote:
It's not about filleting...
That contradicts you previous post.
Over the years (and acceptance of many proposed changes) I have found the most effective way of getting them accepted is by providing concrete examples that clearly and convincingly illustrate the benefit.
I can’t even figure out your example.  It is not clear and convincing to me.
Can you create a video or a better example?
Message 35 of 83
adam
The image is simply to indicate what the missing feature is, ie.: The big red text and arrow pointing to where the "show construction geometry" check box aught to be.  The sketch there is just a random bit of drawing.
As you'll note, I'm not the OP of this thread (or the many others like it) and several others in this thread ask why the feature is missing.  It would be a useful feature (and one I believe was accepted, but never implemented, several years ago).
I learned on autoCAD back in the 90s, where I was used to putting construction geometries on another layer and simply hiding that layer when I didn't want to see or interact with it.  I guess, the feature I would like to see is the equivalent of a construction layer in the sketch, which can be toggled on and off.
Construction lines can get very crowded, so it's nice to be able to hide them, in order to see the outline you are creating more clearly.
Further, where you have a solid line on top of a dashed line, it's a fiddle to select the correct line when performing an operation like filleting (for example) where, sometimes, fusion creates a fillet between the dashed line and the solid line (and messes up the geometry or fully defined status of the drawing).
I have never created a screen-cast, so I'd have to figure that out...
Message 36 of 83
g-andresen
In principle, it is understandable to hide construction lines.
However, it is important to remember that they remain part of the sketch and therefore also contribute to whether a sketch is fully defined or not.
For example, if you create a construction line with open ends, the sketch will be marked as "Not fully defined".
günther
Message 37 of 83
davebYYPCU
I am one who prefers to see what’s in the sketch, and to provide some balance, don’t want them hidden, User option would not be a benefit to me.
Message 38 of 83
adam
Here is a (very basic) example of a time it would be useful to be able to hide the construction lines while performing an operation...
https://knowledge.autodesk.com/community/screencast/ca6bc85d-3151-4764-99fe-308a8942307d
Message 39 of 83
davebYYPCU
Semantics -  2 out of 2
both examples now of where construction lines have no purpose.  I use and need construction lines, but not as you demonstrate.
if I needed that outcome, construction square is last.  You will soon learn that Fusion will object to the duplicated diagonal confusion.
Message 40 of 83
adam
For the same reason you might want to hide dimensions or projected geometry - to make things clearer and simpler when you don't need that extra detail cluttering up the workspace.
And where you wan to trim, fillet etc. in places where there are construction lines on top of solid lines.
You might be far more efficient than me in your use of construction lines, and the example I posted was the simplest I could think of, to show the problem.
I know it's not impossible to work around this in most instances, but it would just make life easier sometimes and seems like an obvious and straightforward improvement to the sketch environment.
