How do I get both sides to match?
FacebookGroupMember
Message 1 of 15
FacebookGroupMember
How do I get both sides to match? Is there a way to make the flange copy the curve from the opposite side?
Replies (14)
Message 2 of 15
FacebookGroupMember
Can you record you walking through your full timeline?
Message 3 of 15
FacebookGroupMember
Use mirror
Message 4 of 15
FacebookGroupMember
Zach Carrizales
Message 5 of 15
FacebookGroupMember
Arkadiusz Noga I did try that and it would mirror the side I needed but wouldn’t let me connect them like it was all one piece
Message 6 of 15
FacebookGroupMember
Arkadiusz Noga I can mirror like this but don’t know how to connect them where both sides are a bend?
Message 7 of 15
FacebookGroupMember
Pull the flange longer, start a sketch on its face, project the curve and extrude cut.
Message 8 of 15
FacebookGroupMember
Message 9 of 15
FacebookGroupMember
Carl Barker that makes sense I’ll try it thanks
Message 10 of 15
FacebookGroupMember
Mike Campbell If you have positioned your part over a midplane - the easiest task (as other people have mentioned is a mirror). I would extrude your second flange to half of the desired width and Mirror over that face.
Message 11 of 15
FacebookGroupMember
Carl Barker this worked perfect thanks
Message 12 of 15
FacebookGroupMember
This is what I do for similar things, do you know if there is a way to do it on angled flanges and have the "cut edge" perpendicular with the flange edge still? (For working with sheetmetal and cutting them from 2d flat patterns)
Message 13 of 15
FacebookGroupMember
Bork Leeson project the curve as above, but instead of extrude cut use split face. then unfold the part and do the extrude and refold, You'll get normal edges then. Sometime you'll be able to use push/pull (offset face) the remove the material instead of unfolding and extruding.
Message 14 of 15
FacebookGroupMember
Awesome, thanks mate!
Message 15 of 15
FacebookGroupMember
This shows the idea, Was done to show angled cuts over bends, but might help explain. https://knowledge.autodesk.com/community/screencast/884bcc59-0476-4358-b369-cf8fb40650a5
