Hello
I made model of cylinder with some holes in it (picture below).
How do I generate a paper template from face (selected on picture) so I can glue it to metal pipe and drill out those holes?
I am unable to make templates out of sketches because as far as I know there is no tool in Fusion to wrap sketch around tube.
Best regards
Andrzej Goslinski
Solved by HughesTooling. Go to Solution.
If you don't mind starting again you could design it as a sheet metal part. I made the screencast below as an example for someone else. When you have the design finished you can create a flat pattern and create a 2d drawing you can export as a PDF file.
Mark Hughes
Owner, Hughes Tooling
Thanks for answer, I wanted to avoid modeling it from scratch but I think it is unavoidable.
ExactFlat works like a charm, initially I ignored it because I thought that it is not free.
As of 2019, please disregard any advice to try Exactflat. The company have removed their 30 day option and the yearly subscription is eye-wateringly expensive. What's more, the customer service cannot be considered polite.
Meshmixer will produce patterns. The process is tricky and laborious but works. It is also free.
