How do I delete a title block
I have searched for 30 minutes without success.
At the bottom of the screen when editing a drawing there are five buttons. The right one is labeled Sheet Settings when you hover over it. There is a check box for showing the title block and one for showing the border.
andrew.de.leon
Hi Lynn,
Sorry it took so long to find this option Smiley Sad
Just curious if you tried the Delete command (found in the Modify panel within the toolbar)? It should allow you to select the title block and delete it. Alternatively, selecting the title block and pressing the DELETE shortcut key should also delete it.
Andrew
15" Retina MacBook Pro (Late 2013), OS X Sierra (10.12.1), in Sydney Australia
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
