How do I define/constraint natural shapes?
autodeskN884Q
autodeskN884Q
I've created a water-drop like shape with the point spline tool
What is a good practice to define and constraint such a natural shape?
Export is attached.
Phil.E
It depends on what you are trying to make.
If you want this to be "regular" meaning it needs to be centered on the origin and symmetrical, you can try two workflows.
1. Add constraints to every spline object (nodes, handles, curvature handles). This would be about 6x the amount of constraining you need to do if you aren't using splines.
2. Or draw this without splines.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
mango.freund
it makes no sense to measure this natural structure. just for such a case there is the possibility of fixing. greetings mango
