How do I create parallel fillets?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to create three parallel fillets on a sketch that maintains the correct internal spacing. For example, the distance between an inner rectangle and an outer rectangle is 4mm. I want them to maintain a 4mm distance apart throughout the fillet. I can get this to work if I create the shapes using the offset tool, but can't with the individual fillet tool. The goal is to be able to update the radius with an attribute.
Not working:
Working using Offset:
