How Do I Constrain....
I'm importing a Solidworks design into Fusion, and re-constructing all the features. My process is, generally, to import the Solidworks part file, enable the Timeline, and create one or more sketches containing projections of all the necessary geometry. I then break the link to the imorted geometry, fully define the sketch, and use it as the basis for the new feature created as Fusion bodies. When the new model is complete, I delete the imported model.
But, I have one persistent problem I haven't been able to resolve. In almost every case, some feature in the projected sketch, typically a circle, needs its center to be anchored to the sketch origin. But, I have been unable to find any way to apply a coincident constraint between the origin point and the center point of the circle without first move the circle AWAY from the origin point, which screws up other geometry. HOW/WHAT do I have to select to make the circle coincident to the origin without moving the circle?? I seem to be able to select either the circle center, or the origin, but not both. Holding the mouse button down while over the origin does NOT give me the pop-up select menu. What is the trick?
Ray L.
