Hi Guys,
I'm honestly astonished to see Autodesk's position here. I've worked in industry for 10 years and I've used several CAD platforms including Solidworks, CATIA, NX, Pro-E, etc. All of the other CAD softwares support this feature. The fact that we simply cannot change an existing drawing from inches to mm and back and forth is incredibly frustrating. It shows a deep lack of understanding of how design and manufacturing work in the real world.
On several projects, we send out 2D drawings in mm and inches to diversify our quoting and supply management process. Having to make a brand new drawing just to switch units is not only a huge waste of time, but it makes for an opportunity to make more human errors whether it is a drawing missing information or inconsistent information between supposedly equivalent parts.
On top of that, I went to create a drawing today with my standard ASME B size format that I have saved. As it turns out, I have to create a whole new drawing format to create a drawing in mm. Once again, huge waste of time. My current workaround is to avoid doing ANY drawings in Fusion, export the STEP files and do the drawing in another CAD program, not named Fusion 360.
The 2D drawing features and support in Fusion 360 are so bad that I'm not sure that Autodesk can call this a full CAD solution. Whether it is no support for weld symbols, or the inability to make simples changes in units, Fusion 360 has a long ways to go. And here you guys are, adding things like generative design into the features. Yeah, that's nice and sounds good on a marketing white-paper, but how about THE BASICS?!? The original post for this issue was 6 years ago. So at this rate, I would imagine it will never change...
