Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How can I split this bodies edges?
2 REPLIES 2
micfin0809
1948 Views, 2 Replies
I made a body and then shelled the inside and then filleted the corners, the body is a whole however, how do I split the corner from the body? Picture attached.
2 REPLIES 2
jhackney1972
in reply to: micfin0809
I have attached a Screencast showing my method, as I am sure there are others.  I have also attached the model for you to follow the timeline or practice on the opposite side.  My two split bodies cut the corner out also.  If this is undesirable, then another curved surface split plane will need to be used and another combine to put the corner back.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jhackney1972
in reply to: jhackney1972
Here is the model of the just the radius corner removed.
John Hackney
Retired
Technology Administrators
